05 trailblazer sway bar problems,
my sway bar links and bushings are both bad, would they cause a wheel vibration/bounce like they are out of balance but just had them re-balanced and an alignment done, all four tires are only a couple of months old, also noticed that my front tires were cupping as well, I just replaced had new struts w/springs installed, new ball joints. new rear shocks, the only thing I see that is bad are the links & bushings,, ANY HELP WOULD BE MUCH APPRECIATED..
sway bar problems will not cause a vibration. driving straight on level surfaces the sway bars impart nothing and have no effect on anything whatsoever.
if you have feather edgewear on only the inner or outer tread of the tire and not across the entire face of the tire...it is a toe wear issue. If this wear was not from before the alignment...the alignment needs to be rechecked.
does the steering has poor return to center after turning?
