TrailBlazer 2002-2009
09 Trailblazer intermittently drops temp gauge to 0
Old Jul 16, 2018 | 1:34 PM
Tyler Joyce's Avatar
Default 09 Trailblazer intermittently drops temp gauge to 0
While driving, usually in the morning, my temp gauge will drop to 0 and the AC will stop working. I have been able to fix it by pulling the negative battery cable and reset the ECU, everything works as it should immediately. I have tested the harness going to the sensor and it has both 5v and continuity to ground. The sensor read around 500 ohms when I tested it. All hoses are hot and have pressure as they should. What's going on here? Any ideas?
Old Jul 16, 2018 | 3:33 PM
kevinkpk's Avatar
Not sure about the resistance, that will be determined by the temperature. I'd replace the temp sensor. Might check good static, but might not otherwise.
Old Jul 24, 2018 | 7:29 AM
Replacing the temp sensor didn't fix it. The old one tested fine. Keep in mind that resetting the ECU fixes the problem for a little while after it drops out. It fixes it immediately too
Old Jul 31, 2018 | 8:53 AM
Bump.
