TrailBlazer 2002-2009
2002 Chevy Trailblazer rough idle
Old Mar 17, 2018 | 2:17 AM
Bruce Pennington II's Avatar
Default 2002 Chevy Trailblazer rough idle
I have a 2002 Trailblazer that just had a bad thermostat replaced after months of it being stuck open and two days later the car suddenly idles rough and at around 50-55mph seems to lose power. The only code being thrown is for camshaft position sensor electrical fault but that was thrown way before this happened and I put a new sensor in it after thinking it may have been the problem but when I try to do the relearn procedure the car will not Rev up to the 5000rpm mark needed for the procedure. I put on a new clean throttle body but that didn't fix anything ethier.
Old Mar 17, 2018 | 8:37 AM
04redCATeyes's Avatar
relearn for trailblazer involves revving to 5k rpm? ive never heard of that
Old Mar 17, 2018 | 1:24 PM
The tool I use says 5200 rpm and I did it successfully before but now that it's idling rough the engine won't go above 4000 rpm so the process fails
Old Mar 17, 2018 | 2:18 PM
i see
Old Mar 19, 2018 | 4:45 PM
vipergg22's Avatar
Not sure was going to say throttle body but you say you either put a new one on or cleaned the old one . Did you pulled fuses 10 and 28 for 30 minutes after the throttle body cleaning , this resets pcm which is needed.
Old Mar 24, 2018 | 2:16 AM
Yes did that but still the same. I have heard it could be a bad catalytic converter.
Old Mar 29, 2018 | 4:05 PM
Mark Spehar's Avatar
I see you replaced the camshaft sensor...now try this little item.ACDELCO12615873Variable Valve Timing (VVT) Solenoid / Actuator
