TrailBlazer 2002-2009
2002 Trailblazer Stereo Help
Old Dec 31, 2009 | 8:23 AM
sd7329's Avatar
Default 2002 Trailblazer Stereo Help
I have a 2002 Trailblazer that is having intermittant problems with the factory radio/CD player. Some days it will work fine with no problems. Some days it will only work with the tweeters in the front speakers. Some days it will only work with one speaker. This is very frustrating! I would just buy an aftermarket radio but want to make sure that would fix it. If there might be an existing seperate amp that is malfunctioning then the aftermarket might not fix it. Any ideas on what's going on? If you need any more info let me know.
Thanks.
Scott
Old Jan 12, 2010 | 9:18 AM
AndrewSE's Avatar
You may have a short in the harness or it is possible the plug has become loosened from the back or has corrosion on it.
No way to tell for sure unless you take it out.
Volt meter is your best friend when diagnosing electrical issues with car stereo wiring.
Old Jan 12, 2010 | 8:55 PM
shawnvw's Avatar
Banned
do you have a bose system? it will say bose on the front door speakers and you will also have little speakers in the dash.
Old Jan 28, 2010 | 6:24 AM
sd7329's Avatar
I ended up taking it out to replace it with an aftermarket unit. The original was not a bose system. There were no signs of corrosion or loose connections that I could find. I installed the aftermarket one and it works great! Must have just been the original head unit itself was going bad. Thanks for the help.
Scott
Old Jan 31, 2010 | 12:53 AM
JamyElson's Avatar
Default Hi
Honey why dont you try out Audio Pro Stereo Zero its a very hifi sound system. My cousin has fixed it in his car and it rocks. you can read its reviews at http://www.testseek.com/home_electro...b310673ea.html if you like but I really enjoy listening too rocking music.
Old Sep 2, 2015 | 10:02 PM
Mary Jane Fabisch's Avatar
Default 2002 trailblazer radio, cd player help
My 2002 Radio/Cd player is locked in the CD mode and will not change and I cannot eject CDS.. What could the problem be?
davet
Feb 17, 2022 8:08 PM
trucknoob45
Aug 16, 2014 8:16 PM
Sweettaz88
Sep 28, 2012 11:13 PM
cube4hire
May 8, 2007 9:03 PM
