TrailBlazer 2002-2009
Old Jul 24, 2015, 4:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
2004 Trailblazer Fan Clutch Issues
Old Jun 26, 2014 | 11:25 AM
gdc4sman's Avatar
Default 2004 Trailblazer Fan Clutch Issues
My '04 TB LT fan started to intermittently fully engage at 97k miles causing the jet engine noise along with sluggish power (No engine codes). Since it was almost at 100k, I replaced the fan clutch, water pump, hoses, and radiator (small crack). The fan clutch was the Hayden 3200 model and new out of the box was worse than the OEM clutch I just replaced (Extremely loud jet engine noise). I returned it and replaced it with the DORMAN model and then had the dealer update the PCM firmware. Now I'm back to square one, as the clutch intermittently locks with the same issue and still no engine codes. From reading other forums, I'm guessing that the problem might be one of the sensors not working properly (Engine coolant temp sensor, transmission temp/manifold press sensor, or A/C pressure sensor).
My first inclination is to replace the Engine coolant temp sensor and thermostat even though the engine temp gauge shows a steady 210 degrees regardless of when the fan clutch is engaged or not. Any suggestions/recommendations would be greatly appreciated.
pdrayton
10
May 5, 2024 2:27 PM
pdrayton
May 29, 2013 7:55 PM
Lindsay Kreis
Jul 6, 2012 6:19 PM
SweetEmotion
Apr 27, 2012 8:35 PM
jdaughtry002
Jun 22, 2010 10:56 PM
