TrailBlazer 2002-2009
2006 Chevrolet TrailBlazer 5.3 help!!
Old Apr 16, 2026 | 7:47 PM
Kortnee's Avatar
Default 2006 Chevrolet TrailBlazer 5.3 help!!
Please can someone tell me what this is? It was broken off the back somewhere near the engine valley pan. I know it sits near the oil pressure sensor. It's NOT the camshaft position sensor, I have a LH6 engine so I know the camshaft position sensor is in the front. Whatever this is it causing misfires on 1,4,6 and 7.
Old Apr 18, 2026 | 8:45 AM
chem_man's Avatar
15 Year Member
What you have pictured is an AFM Connector for the Active Fuel Management (AFM) that is incorporated into the 5.3 L engine.
Not sure if it can be replaced by itself, or if it needs to be part of the Valve Lifter Oil Manifold (VLOM) which controls the deactivation of the various cylinders when the AFM system is engaged. Here is a link to a VLOM replacement - https://www.dormanproducts.com/p-130...origin=keyword assembly
The VLOM assembly is also called a Cylinder Deactivation Solenoid
Here is another link for the assembly: https://www.rockauto.com/en/catalog/...solenoid,19951
Old Apr 18, 2026 | 12:01 PM
Kortnee's Avatar
Thank you so much!
GrewarO
Nov 25, 2024 12:44 AM
Chester Ramos
Apr 27, 2021 8:56 AM
Chester Ramos
Apr 23, 2021 11:16 PM
dpena602
Mar 30, 2015 5:28 PM
75rat
Apr 25, 2010 12:37 PM
