TrailBlazer 2002-2009
2006 Trailblazer NO CRANK
Old Apr 28, 2013 | 9:06 PM
Brad90T's Avatar
Default 2006 Trailblazer NO CRANK
Hi My name is Brad and I am new here. Let me start off by saying thank you to any and all that reply. As the title says 2006 Trailblazer 4.2L no crank. Drove to Wal-Mart started and run great, came out and all the dash lights on but no crank. Thought ok batt is dead. Hooked jumper cables up and still the same. I am thinking ignition switch, but they are pricey, and I don't wanna throw parts at it. Any and all help greatly appreciated.
Old Apr 29, 2013 | 8:02 AM
kevinkpk's Avatar
Check the main wire from the solenoid, I believe it has a fues link in it.
Old Apr 29, 2013 | 8:35 AM
M800's Avatar
It might be the wires going to the starter or it might be the starter is bad
Old Apr 29, 2013 | 9:47 AM
Brad90T's Avatar
Checked power to starter with a test light, have main power and power at the ingnition post. Thought ok bad starter. Had it towed home and the towtruck driver tried his jump box still no start. Checked battery voltage with a volt meter and it was at 8.24v. Put a charger on it for 15 minutes and hit the key and it started. I don't understand why it wouldn't jump, and hope that it is the battery cause I don't have the money right now to get expensive parts.
Old Apr 29, 2013 | 12:32 PM
kevinkpk's Avatar
Bad connection probably. I have a pair of heavy duty cables that are VERY picky.
fitzpatrick44
Jun 8, 2015 8:02 PM
boosyah
Feb 15, 2014 9:42 AM
nigel.durrant
Jan 29, 2014 11:44 AM
hillbillypimpin
Uplander
Sep 8, 2009 9:12 PM
