TrailBlazer 2002-2009
2006 Trailblazer SS Turbo Build
Old May 11, 2024 | 5:15 PM
  #11
autowiz's Avatar
Here is the fuel injector prep for E85 and install..
Old May 12, 2024 | 9:04 PM
  #12
autowiz's Avatar
Do NOT buy Ebay turbo hot parts for your Trailblazer SS. They do not fit..
Old May 16, 2024 | 11:19 PM
  #13
autowiz's Avatar
We went with a large intercooler with 600x300x100mm dimensions and 3" inlet/outlet. Had to do some cutting to make it fit, but it does fit.
And looks pretty menacing behind the fascia..
Old May 23, 2024 | 5:30 AM
  #14
autowiz's Avatar
Fuel pump setup keeping the bucket that holds fuel. This Trailblazer SS will stay in fuel under power with a low fuel level in the tank. Something you won't get with a multi pump setup. Hey did you guys know the Trailblazer SS tank does not have baffling inside? It only has the fuel pump module with return dumping into it's own bucket and a one way check valve to keep the pump in fuel while the truck is experiencing inertia. Be it from throttle or brake. Food for thought.
Here is how you can get the most out of a single 450LPH pump..
Old May 31, 2024 | 10:43 AM
  #15
autowiz's Avatar
We finally got around to fixing the manifold. The Turbo Trailblazer SS is almost ready to run.
Old Jun 4, 2024 | 11:30 PM
  #16
autowiz's Avatar
The crossover pipe and downpipe are made and installed. The Turbo Trailblazer SS is very close to being ready to start.
Old Jun 21, 2024 | 12:13 AM
  #17
autowiz's Avatar
We are nearing the end of our project. The Turbo Trailblazer SS started today..
Old Jun 30, 2024 | 10:32 PM
  #18
autowiz's Avatar
All the cool cars pull up to the yellow pump..
I was out and about logging data and street tuning this turbo Trailblazer SS today and took a few pictures of this awesome truck..
We still have some tuning work to wrap up but the truck drives nice and we are logging boost levels as high as 10psi.
Old Jul 2, 2024 | 12:30 AM
  #19
autowiz's Avatar
We are only running it at 12psi for now. We will turn that up later. We are just being nice to the new engine for a few tanks of fuel. Here is the complete turbo TBSS just before delivery back to our customer..
Johnny Mayday
Oct 17, 2017 6:43 PM
Falbo80
Feb 10, 2016 3:48 PM
dogfish246
Feb 7, 2014 7:04 PM
ajth87
Jan 30, 2008 9:27 PM
