TrailBlazer 2002-2009
2008 Trailblazer Suspension/Axle Questions
Old Nov 5, 2008 | 8:53 PM
jpbjr1955's Avatar
Default 2008 Trailblazer Suspension/Axle Questions
Good day from a new member and a newbe Trailblazer fan.
I am looking at a Certified used 2008 Trailblazer, 16K miles. I understand that the VIN can be run ( 1GNDT13S682106035 ) to obtain the list of RPO codes for the options present on the vehicle and have asked the dealer to do so. He indicates that although this can normally be done he can not do so on this vehicleasitwas originally purchased by a Major Rental Agency and that the information was somehow locked and not accessable. Does this seem likely?
The vehicle is in pristine condition but seems to ride a little "harsher" than 2 other Trailblazers I am looking at. This makes me wonder about the suspension that may be optioned on it and thus the VIN code request.
My specific areas of interest are thesuspension package (premium smooth or not) , GVWR (std or 5750#), locking rear axle or not andaxle ratio (3.73 or 3.42). (I would like to use to tow a boat overreasonablely short to moderate distances a couple of times a year.)
I know that I can try to get him to let me took at the codes on the buildlist within the vehicle but that seems like a lot of work and I am not quite sure just where to look on this vehicle to find the sticker(s) with this information.
I am not sure just how the premium suspension and 5750# GVWR availability interact with each other or not and neither is this dealer. Also which axle ratio would come as standard on this vehicle?
These are probably a lot of strange questions but Ithought that this would be the place where the experts would reside and know the answers.
THANKS in advance!
John
Old Nov 6, 2008 | 7:23 PM
shawnvw's Avatar
Banned
Default RE: 2008 Trailblazer Suspension/Axle Questions
That guy was so full of it, it should have been spilling out his ears.......
ZW7 Chassis Package - Premium Smooth Ride
[/size]GU6 REAR AXLE 3.42 RATIO [/size]
Gross Vehicle Weight Rating : 2611 kg (5757 lb)
Could the 4X4 switch have been on while you were on a test drive? that changes the way it drives
VIN [/size]
1GNDT13S682106035 [/color]
VEHICLE BUILD
Merchandising Model :
CT15506-2008TRAILBLAZER 3LT 4WD
2611 kg (5757 lb)
Order Number :
MCKRRR
Build Date :
07/24/2007
Build Plant :
[size=2]18206
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker. [/b]
[color=#0000a0]OPTION CODES
AAB - MEMORY SEAT ADJUSTER
AJ1 - GLASS, DEEP TINTED
AK5 - AIRBAGS, DUAL FRONTAL PASSENGER SENSING SYSTEM
AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD
AM9 - 65/35 FOLDING 2ND ROW SEAT
AR9 - SEATS, FRONT BUCKET, POWER SEAT AJUST-DRIVER 8 WAY
AT8 - RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING
AU0 - REMOTE KEYLESS ENTRY (INCL: THEFT DETERRENT SYS)
AXP - MPV VIN INDENT POSITION
BVE - RUNNING BOARD, ASSIST STEPS
B0M - GM PRODUCTION WEEK #30
B30 - COLOR KEYED CARPET
B32 - FLOOR MAT, FRONT/REAR
B33 - REAR COLOR KEYED FLOOR MATS
B42 - REVERSIBLE CARGO MAT
B86 - BODY SIDE MOLDINGS, BODY COLOR
CJ2 - AUTO DUAL ZONE AIR CONDITIONING
C49 - REAR WINDOW DEFROSTER
C5N - GVW RATING - 5750 LBS
DAY - ASSEMBLY PLANT MORAINE, OHIO
DD7 - INSIDE REARVIEW MIRROR, AUTO DIMMING, COMPASS
DH2 - VISOR MIRRORS, LIGHTED
DK7 - OVERHEAD CONSOLE
DS3 - POWER HEATED OUTSIDE MIRRORS W/ TURN SIGNALS
DT4 - ASHTRAY AND LIGHTER
EVA - EVAP EMISSION REQUIREMENT
FLT - FLEET PROCESSING OPTION
GU6 - REAR AXLE 3.42 RATIO
JF8 - ANTILOCK BRAKES, 4 WHEEL DISC
JJB - PT DRESS SUBASSY NOT INSTALLED
KA1 - HEATED FRONT SEATS
KCV - VANGUARD CAR RENTAL
KG4 - GENERATOR 150 AMP
K18 - ELECTRIC AIR INJECTION SYSTEM
K34 - CRUISE CONTROL
LL8 - ENGINE, VORTEC 4.2L SFI I6
M30 - TRANSMISSION, 4 SPD AUTOMATIC
NP8 - AUTOTRAC FOUR WHEEL DRIVE
NU5 - EMISSION SYSTEM CALIFORNIA
N40 - POWER STEERING
N79 - WHEEL, 17" FULL SIZE SPARE
PD8 - 18" POLISHED ALUMINUM WHEELS
QZD - ALL SEASON TIRES
R6F - IDENTIFY B CODE USERS
R6K - PROCESSING CODE
R9N - PROCESSING CODE - SEAT
STW - LEATHER WRAP STEERING WHEEL W/ RADIO CONTROLS
TB4 - LIFTGATE
TFD - RETAIL AMENITY DELETE
TGA - LANGUAGE CONTROL ENG, FR, SPAN
T61 - DAYTIME RUNNING LAMPS
T96 - FOG LAMPS
T98 - STAMPING VEHICLE IDENT NUMBER
UA6 - THEFT DETERRENT ALARM SYSTEM
UB0 - AM/FM STEREO, CD PLAYER
UE1 - 1 YR ONSTAR SAFE & SOUND (ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE)
UG1 - UNIVERSAL HOME REMOTE
UJ6 - TIRE PRESSURE MONITOR
UK6 - AUDIO CONTROLS, REAR SEAT
UQA - AUDIO SYSTEM-BOSE PREM. SOUND
UY7 - WIRE HARNESS, TRAILER
U2J - XM RADIO DELETE
U68 - DRIVER INFORMATION CENTER
U73 - FIXED ANTENNA, RADIO
VH9 - ENVELOPE OWNER INFO MANUAL
VK3 - FRONT LICENSE PLATE BRACKET
VN9 - DAILY RENTAL REPURCHASE PROGRAM
VT7 - OWNERS MANUAL, ENGLISH
VXS - COMPLETE VEHICLE LABEL
V1K - LUGGAGE RACK CROSS BARS
V40 - PWR SEAT ADJ-PASSENGER, 8 WAY POWER LUMBAR, FRONT PASSENGER
V73 - VEHICLE STATEMENT - USA/CANADA
X88 - CHEVROLET CONVERSION
YA7 - CALIF. ASSY. LINE EMISSION TEST
YC6 - LT CONVENIENCE PACKAGE, UPLEVEL * MEMORY SEAT ADJUSTER * POWER HEATED OUTSIDE MIRRORS W/TURN SIGNALS * HEATED FRONT SEATS
YD3 - AXLE (BASE EQUIP)
YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING
YF5 - 50-STATE EMISSIONS
YT1 - DAILY RENTAL FLAT RATE DEPREC.
ZQ3 - DRIVER CONVENIENCE PACKAGE: * INSIDE REARVIEW MIRROR, AUTO DIMMING, COMPASS * AUDIO CONTROLS, REAR SEAT * DRIVER INFORMATION SYSTEM * AUTO DUAL ZN AIR CONDITIONING * LEATHER WRAP STEERING WHEEL W/RADIO CONTROLS
ZTM - SPARE, ALL SEASON TIRE
ZW7 - PREMIUM RIDE SUSPENSION
ZY1 - SOLID PAINT
1SZ - PREFERRED EQUIPMENT SAVINGS
28I - LIGHT GRAY
282 - LIGHT GRAY
3LT - LT PREFERRED EQUIPMENT GROUP 3
37U - IMPERIAL BLUE METALLIC
6PJ - SUSPENSION
7PJ - SUSPENSION
8UZ - SUSPENSION
[size=2]9UY - SUSPENSION
[size=2]
Old Nov 6, 2008 | 9:03 PM
jpbjr1955's Avatar
shawnvw,
I want to thank you for taking the effortto run the VIN togive me such informed answers, especially since the dealer couldn't or wouldn't(although I do take some exception to being discribed as "being so full of it that...."). Yes, I do know the difference between having the XFR case in 2WD which is where it was during my drive (I switched it OUT of AUTO where it had been and INTO 2WD before leaving the dealers lot) and 4WD which would really be pretty hard on things on dry, solid pavement, wouldn't it.
Regardless, the RPO data yousuppliedfrom the VINis GREATLY apreciated. This Trailblazeris a near perfect fit for me. I guess that I had hoped, however,that it had the HD locking differential for the winter snowand the 3.73 gearing to handle a towing load better.Don't understand the difference in rideperception especially since it has the premium smooth ride suspension package; (tires maybe).
Oh well, can't have everything unless it's special ordered new and pay an extra $10,000-$12,000 more than this one is priced.
John
Old Nov 10, 2008 | 2:31 PM
rbarrios's Avatar
not sure I understand your answer...
but just in case...
shawn meant the dealer was full of it- for supposedly not being able to look up that info..
Old Nov 10, 2008 | 2:59 PM
shawnvw's Avatar
Banned
ORIGINAL: rbarrios
but just in case...
yea sorryifI gave you the wrong impression but that it exactly what I meant
Simon-Pierre Lacasse
Mar 8, 2014 7:18 PM
Trey Knight
Feb 12, 2010 3:19 PM
akabavah
Avalanche
Oct 10, 2009 9:54 PM
tatt2kid
Avalanche
Sep 2, 2009 7:16 PM
Fishing
Aug 12, 2007 2:23 AM
