TrailBlazer 2002-2009
Bad A/C clutch
Old Nov 29, 2018 | 2:46 PM
BurnemGarage's Avatar
Default Bad A/C clutch
Recently the A/C clutch on my 06 5.3l v8 trailblazer has started to go bad. It makes a awful clicking noise when it stops spinning. Is it possible to change just the clutch on the a/c or am I stuck with replacing the whole compressor assembly. If it is possible to change just the clutch can I buy them new or must I go to a junk yard and find one?
Old Nov 29, 2018 | 3:04 PM
kevinkpk's Avatar
You can replace just the clutch, since you are asking, that tells me you should look at how big a job that is. Personally, I'd buy a reman compressor ready to install.
Old Nov 29, 2018 | 5:18 PM
You can replace just the clutch but you have to be very careful not to damage the seals in the compressor. There is a special puller and installer to do the job.
Old Nov 30, 2018 | 10:27 AM
Something like this?
https://www.amazon.com/Compressor-Clutch-Remover-Conditioner-Automotive/dp/B01FOQJNPC/ref=asc_df_B01FOQJNPC/?tag=hyprod-20&linkCode=df0&hvadid=198073713294&hvpos=1o1&hvnetw=g&hvrand=7114420556725527194&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9033057&hvtargid=pla-377071586611&psc=1 https://www.amazon.com/Compressor-Clutch-Remover-Conditioner-Automotive/dp/B01FOQJNPC/ref=asc_df_B01FOQJNPC/?tag=hyprod-20&linkCode=df0&hvadid=198073713294&hvpos=1o1&hvnetw=g&hvrand=7114420556725527194&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9033057&hvtargid=pla-377071586611&psc=1
Old Nov 30, 2018 | 10:55 AM
That will work. here is the same one for $5.00 cheaper also at Amazon.
Amazon Amazon
