TrailBlazer 2002-2009
A/C intermittently cooling
Old May 31, 2019 | 1:53 PM
jdfiegel's Avatar
Default A/C intermittently cooling
I have a 2002 Trailblazer and all of a sudden the A/C will stop blowing cool air. The blower is still on in the front and the back but no cool air. This is while I am driving and it is still hot in the car. I live in Texas so you know it is hot here and I need my AC.
I do not get any codes when this happens and I do not hear any noises or clicks when this happens. If I leave it off for awhile it may start working but will eventually stop working again. What could this be, short on Freon or is this something else?
Old May 31, 2019 | 7:13 PM
oilcanhenry's Avatar
Could easily be low on R-134A Freon. You need to put a gauge set on it to find out. Always wear eye protection and gloves when working with A/C pressures.
Old Jun 1, 2019 | 1:54 AM
KChevy75's Avatar
I'm not familiar with the Equinox but I've experienced something similar a couple of my vehicles.
In one, the electric fan that pulls air over the condenser under the hood had brushes that were worn to a nub and they could no longer make contact.
In the other, the electric fan was seized up.
This causes the refrigerant to not be able to condense back to a liquid,
In my case, when I drove at highway speed, it would start cooling just slightly because of the increased air flow over the condenser..
Old Jul 9, 2019 | 3:48 PM
jdfiegel's Avatar
It was low on Freon but the issue ended up being the low pressure port valve core was leaking. Tried tightening but still was leaking. replaced it and charged back up and all good.
Thanks for all your help.
Old Jul 12, 2019 | 8:51 PM
I am very glad that you solved your issue!
