TrailBlazer 2002-2009
Changing spark plugs
Old Aug 29, 2010 | 8:50 PM
yezzell04's Avatar
Unhappy Changing spark plugs
I need help. We changed the spark plugs and after we did that, the truck started shaking real bad. So I am wondering, was there something special we were supposed to do before changing the spark plugs to a 2005 Chevy Trailblazer.
Old Aug 29, 2010 | 8:58 PM
MDTAHOE's Avatar
Professional Mechanic
What kind of plug? Did you check the gap?
Old Aug 29, 2010 | 9:11 PM
yezzell04's Avatar
Well at first we didn't check the gap, because we were under the impression that all spark plugs were already calibrated. Even after we calibrated them it still did the same thing and they were the cheapest brand I don't remember. I just know that they were not AC Delco.
Old Aug 29, 2010 | 9:39 PM
gotstylez's Avatar
did you do 1 plug at a time? you might have mixed up a plug wire if you didnt
Old Aug 30, 2010 | 4:15 PM
MDTAHOE's Avatar
No plug wires coil over plug. Unless it is a 5.3 I would bet the plugs are wrong. Cheap is never good.
Old Aug 30, 2010 | 9:40 PM
gotstylez's Avatar
good catch MD..never thought of that..
Old Aug 30, 2010 | 9:54 PM
yezzell04's Avatar
What do you mean by "wrong" The wrong kind?
Old Aug 31, 2010 | 8:27 PM
MDTAHOE's Avatar
What Brand? If it came with Iridium. platinum or double platinum you must use that, you can not use a cheap copper core plug. They may have a listing for it but that does not mean it will work. If the plugs were not at least $6.00 each (probably more) they are wrong. Who makes the plug, what is the part # ?
Old Sep 3, 2012 | 5:34 PM
Goon512's Avatar
New User
Awaiting E-mail Confirmation
I have same problem I use auto lite and I gap them myself and I kno I did that right but seems like its missin out did it one by one soo I wouldn't mess up but it's jus take a min to get to 40mph I used auto lite brand pllllzzz help asap
Old Oct 17, 2012 | 9:56 AM
calgaryjeff's Avatar
Put a scan tool on it. I bet you get a "misfire" DTC. Either one of the coils did not seat properly on the plug or you have a bad coil. Also, make sure the connectors on the coil are clean and properly clicked on.
