TrailBlazer 2002-2009
Code P0526 cooling fan
Old May 30, 2018 | 7:27 AM
Paulie710's Avatar
Default Code P0526 cooling fan
I recently bought 06 Trailblazer he kept coming up with code P 5026 cooling fan what clutch fan I checked the fuse number 20 check the relay I think it's number 45 or 46 then I change the cooling fan clutch I still come up with the same code p0526 is there a way to jump this to make sure the new cooling fan is even any good or any other ideas on which way to check it out
Old May 30, 2018 | 8:32 AM
make sure the cooling fan harness has not rubbed through on the plastic guide it routes through.
Old May 30, 2018 | 10:41 AM
Paulie710's Avatar
Default Cooling fan
If you are talking about the guide where the harness connects and goes into the fan shroud that came with the new fan clutch
