Do I have a PCM problem???
lets start from the beginning, I have a 2005 Chevy Trailblazer LS with the 4.2L inline, the fuel gauge was acting up, and the car stalled once and the exhaust smelt funny, after some research found that the problem was most likely was the result of a bad fuel pump, so i replaced it. When I completed the replacing the fuel pump i put in 10 gallons of gas and the gauge read correctly, i then let the truck run for a few minutes then then when i went to back out of my drive way the truck stalled out, so i restarted it with out a problem drove to the local gas station and filled it up and read correctly, then on the drive back home the gauge started to read incorrectly.
Could this be a possible Powertrain control module problem?
Thanks for the advice in advance
It's pretty rare for the computers to be faulty. Start with the basics --- air , spark and fuel.
A bad wire or connection to or at the tank could cause the stalling.
Beer
Nov 15, 2010 4:50 PM
Samuel Ross Lollar
Sep 18, 2010 7:59 PM
