TrailBlazer 2002-2009
Fuel leak
Old Jun 26, 2019 | 5:48 PM
Jeff Frahm's Avatar
Default Fuel leak
Fuel leak where vacuum line goes in to the vortec cover. Anyone deal with this? Any help in how to fix it would be appreciated.
Old Jun 27, 2019 | 9:28 AM
oilcanhenry's Avatar
Looks like a vapor line to me. It's not the PCV. Likely you are going to need a new vapor canister which is why you smell gasoline. No way that is a gasoline line..
Old Jun 27, 2019 | 10:50 AM
Jeff Frahm's Avatar
Yea, This is my son's vehicle, so I have not seen it other than this photo. After some research on the web. I believe the other end of that vacuum hose is connected to the fuel pressure regulator. I have a feeling the fuel pressure regulator is leaking and the fuel is going up that vacuum line and leaking out at the top where it goes in to the air resonator. I don't think there should be any fuel in that vacuum line. Pretty sure we just need to replace the fuel regulator.
