TrailBlazer 2002-2009
grinding in brakes when turning right...2003 trailblazer
Old Sep 12, 2016 | 6:38 PM
chevy4life402's Avatar
Default grinding in brakes when turning right...2003 trailblazer
I've replaced both ball joints tie rods wheel bearing hub and brakes and rotors. When I make a right handed turn there is a grinding noise coming from front passenger tire sharper the turn louder the grind. I previously replaced the front rotors and brakes but just on the passenger side started to get 3 grooves in the rotor and the pad had 3 lines that were raised. I hadn't replaced the wheel bearing hub when I first replaced the rotors and pads so I took them back am got new ones thinking it was the hub and just needed new rotor and pads again but it still does it also putting a lot of brake dust on the rims. I don't know what to do but don't want to keep spending money guessing. If anyone has any ideas or has dealt with this before and knows what it is I would really appreciate it.
Old Sep 13, 2016 | 2:41 PM
kevinkpk's Avatar
Are the wheel bearings installed correctly, not overly tight, ect.?
