TrailBlazer 2002-2009
How to wire PAC Pro4 GM11 The NAV/Radio antennas wires where easy.
Old May 25, 2018 | 6:48 PM
the Brain's Avatar
Default How to wire PAC Pro4 GM11 The NAV/Radio antennas wires where easy.
How to wire PAC Pro4 GM11 The NAV/Radio antennas wires where easy.blaupunkt portland.
07 saab 97x same as trailblazer
Managed to connect a couple wires hopefully correctly.
I assume blaupunkt refers to reverse lights as to brake detect.
I assume blaupunkt refers amp on as amplifier control so far to labling is a toss-up.
I connected the fatter yellow to yellow.
I don’t think I use any speaker wire from HU? or the RCAs
The blaupunkt initial configure settings aren’t listed or recognized by pac4. I'm basically guessing a cable labling by using same color.
can't find PAC4 orange w/ white stripe
there are 2 black wires from the blaupunkt one fatter, the PAC4 only has one black wire.
The blaupunkt initial configure settings aren’t listed or recognized by pac4. I'm basically guessing a cable labling by same color.
can't find PAC4 orange w/ white stripe or blue same color from blaupunkt
thanks for any helpfull advice
Attached Thumbnails How to wire PAC Pro4 GM11 The NAV/Radio antennas wires where easy.-installation-wireing2.jpg
Old May 27, 2018 | 6:24 AM
the Brain's Avatar
the blue PAC Pro4 RP4-GM11 has a 1' long cord I have one end terninated into box other end of cord is 16awg blue wire and 3.5" ternial.
so w/out the 3.5" port on back of blaupunkt so I assume I can't plug in the PAC4 is this true or false?
Amazone initialy thought it would physically fit apparently the blaupunkt can't be electrically connected.
thanks
