TrailBlazer 2002-2009
ignition key stuck in on position and can not turn car off
Old Feb 21, 2018 | 1:42 AM
Shawnlong823's Avatar
Default ignition key stuck in on position and can not turn car off
I have a 2010 Chevy Aveo LS (manual) and the ignition key stuck in ON position and can not turn the car off without disconnecting Battery cables. I was told that the Ignition Cylinder needs to be replaced but I'm finding out that I cannot remove the old one because I cannot get the key to turn to the ACC position in order to remove it. Please Help.
Shawn
Old Feb 21, 2018 | 10:41 PM
BoosPrincess's Avatar
Not sure if this helps, but I'm having the same issue with my 2012 Chevy cruze I discovered a hole in steering wheel right below that contains a switch that manually overrides the security lock feature . I still haven't found out what's causing it. But at least I can take my key out.
Old Feb 22, 2018 | 7:04 AM
Thanks for response. I was told about that feature but was also told by the Chevy Dealer that It will not work if the key is stuck in the on position. However, I have not personally tried locating it too see if it works. I will, however, see if I can locate it today. Thanks again for your response.
