TrailBlazer 2002-2009
intermittent engine vibration
Old Nov 24, 2008 | 9:39 AM
phishfood4311's Avatar
Default intermittent engine vibration
hello all.
i have a 2003 tb 4.2l 2wd
problem i have is an intermittent vibrationwhile in gear at idle.
i can go a whole day and not feel it. it can be heard inside the cab.
i removed the trottle body and clean it. i replaced the spark plugs. no change. seems to be worse when cold. seem to run fine a any given speed. vibrates just off idle and just bfore returning to idle. will also vibrate at idle in gear. sometimes while under heavy accelration a
slight miss or vibration can be felt. no dtc's
this problem is really kicking my butt.
Old Jan 23, 2010 | 4:46 PM
stopher2's Avatar
try resetting the ECM.....disconnect batter for 1 hour.
or you can do some 100k scheduled maintenance by trial and error replacements: pressure switch, o2 sensor, mat sensor
frankh65
Colorado
10
Feb 14, 2017 11:46 PM
camperbc
Mar 18, 2012 12:48 PM
greatwhite99
Aug 27, 2011 4:00 PM
JetSnake
Jun 19, 2006 10:10 PM
