TrailBlazer 2002-2009
Low Beams turn off
Old Aug 19, 2007 | 4:48 PM
jimbarton's Avatar
Default Low Beams turn off
I have been having a problem since June, this has happened 4 times since then that the low beams just turn off.
2 weeks ago we were in Florida, and driving down the road and the low beams just turned off, so we pulled
over and all the fuses seemed to be great, and we got back on the road and tuned the high beams on and about
20 min in the ride we checked to see if the low beams were working and they were. The next day we were
leaving Florida and the TB would not start, so someone jumped us off, and we went and got a new battery
and everything seemed to be ok, until last nite, riding down the road and the low beams shut off again??
Has anyone had any problems with their TB doing that. Someone said it could be the
High/Low beam switch or the relay??? Does anyone know if this is something I can
do, or the dealership.
Thanks
Jim
Old Aug 19, 2007 | 8:02 PM
nprdavid's Avatar
Default RE: Low Beams turn off
did you have the alternator checked to make sure it was putting out the proper voltage?
Old Aug 20, 2007 | 6:26 AM
jimbarton's Avatar
We had the alternator checked at O'Reillys and he said it was giving out the correct voltage and etc.
Thanks
Old Aug 25, 2007 | 12:33 PM
p.hinds's Avatar
low beam relay,common problem
Old Aug 25, 2007 | 1:22 PM
jimbarton's Avatar
Do you know how much that would be to replace?
Old Aug 26, 2007 | 7:37 PM
p.hinds's Avatar
under hood fuse box,its named ???anyway its just a replay that pulls out and pushes in,my guess ay e dealer because its called a module would be 35$
dirtrider180
Aug 6, 2022 11:31 AM
Aaron Green
Cobalt
Mar 15, 2015 9:21 PM
Barberryn
Jan 18, 2015 12:05 PM
Barberryn
Jan 18, 2015 11:57 AM
