TrailBlazer 2002-2009
Need some advice on a couple of things on a 2003 Trailblazer I bought
Old Jan 24, 2015 | 10:05 AM
motoman1's Avatar
Default Need some advice on a couple of things on a 2003 Trailblazer I bought
Hey guys and gals, I just joined the site today. I recently bought an extra clean 2003 Trailblazer LS, 2wd w/a 4.2 I-6, w/110,000 miles on it.
As all vehicles with 110.000 miles on it, even though it has been a grocery-getter all it's life, it has some "needs" and has some noises that I am in need of advice on.
1. When it is cold, when I pull up to a stop sign i have a deep sounding vibration that sounds like it could be exhaust related. Listening to it from the inside, it sounds like it is coming from the right side of the motor / tranny area and quietens down after it warms up.
My thoughts are the donut gasket where the exhast manifold and down tube to the rest of the exhaust is going bad and when it warms up it swells and the vibration lessens. Your thoughts?
2. It may still have the original shocks and struts on it. It drives straight as an arrow down the road, but bumps tell the story. BIG TIME.
What would you suggest for new suspenders? I normally use Monroe sensa-trac on cars, but i was wondering if there was something other than Monroe that you all might suggest for a light truck.
Also, the spare tire cable has apparently stretched to the point that it can't be tightened anymore and the tire bumps and squeaks around over bumps. Isn't there someone that makes a rubber spacer that you can put between the rim hole and the plate on the bottom of the cable to take up the slack?
I look forward to your thoughts / insight / experience.
Thanks in advance!
lub
Sep 29, 2015 3:17 PM
2003suburban
Jan 26, 2015 1:37 PM
Zeek19
Sonic (Aveo)
Jun 16, 2011 10:08 AM
countryboy92
May 20, 2011 9:55 PM
