TrailBlazer 2002-2009
Noise
Old Feb 19, 2019 | 4:33 PM
Ann Santiago's Avatar
Default Noise
I have a 07 trailblazer and for the past few months when I start the car it makes such a horrible noise that it sounds like it’s going to explode, also when I turn heat on it sounds like a blower that is clogged? Mechanic said it is the fan clutch and it is wobbly, So $700+ later the car is still making the same noise so now he says it is the heat acuator door? Not sure if he is being honest?
Old Feb 19, 2019 | 6:01 PM
Rednucleus's Avatar
Turn off the heater/ac and work your way through the various controls to see if you can isolate what function causes the problem. Does it sound like it is inside the car or under the hood? Maybe link a video here so we can hear it? Three or four times now our 05 Suburban has had a terribly loud noise at start up that quits when I turn off the heater/ac, then fine once turned on again. My impression is the noise is coming from the a/c clutch, but since so erratic have not figured it out yet.
