TrailBlazer 2002-2009
"normal" running temperature
Old Mar 21, 2017 | 5:45 PM
Whiskey_Sauer's Avatar
Default "normal" running temperature
After the transmission woes, the running temperature went up to 212 degrees. Had the thermostat and thermostat housing replaced, coolant level is full. Bad sending unit?
Old Mar 22, 2017 | 4:10 PM
SBchevyfan's Avatar
More likely the dash gauge is not accurate. I had the same issue with my 95 S-10. New thermostat, new sending unit and still gauge was off. If you can find a non-contact infrared thermometer, run the engine to operating temperature and then check the temp at the thermostat housing. Compare the temp on the dash gauge the reading you got at the thermostat. Also make sure there is no air trapped at the sending unit to give a false reading. If the dash gauge needle doesn't go past this point you should be ok to drive without worry of over heating. It it moves further, into the red, You'll probably have to dig deeper.
Old Mar 25, 2017 | 1:27 AM
Had it professionally checked, they concur the likelihood of a bad gauge, also suspect possible bad sensing unit. Actual running temperature well within acceptible range.
