TrailBlazer 2002-2009
Oil in spark plug hole, what gasket? Fix?
Old Jun 10, 2011 | 11:12 AM
Magnumglide's Avatar
Default Oil in spark plug hole, what gasket? Fix?
Just bought a 2005 Trailblazer with 68k miles on it. I was replacing the plugs when I pulled the plug second from the back, and noticed the threads were dripping in oil and the electrode was crusted and built up with white residue. It's obviously burning oil in the cylinder. Idle and running is smooth. The oil is not above the threads on the porcelain part at all. If correct I believe that eliminates the valve cover gasket as the culprit. It's only one plug, the others are dry.
I haven't had time to check mileage, but thought I noticed a real light hesitation on full acceleration. What's the correct fix if anyone knows? Looks like this is a common problem with the inline 6.
Old Jul 19, 2011 | 8:01 PM
guamtz12's Avatar
i have same problem 2007 trailblazer help?
Old Jul 21, 2011 | 1:12 PM
Chuzz's Avatar
Sounds like a busted oil ring on that piston to me. But keep in mind, I'm not a mechanic. I suppose it could also be a bad valve guide or seal. What say you mechanics?
mamulan
Aug 20, 2014 8:39 AM
TPM
May 14, 2013 5:58 PM
Wick
Apr 24, 2010 4:46 PM
Bill's Dad
Dec 16, 2009 8:43 PM
pete_dallas
Mar 3, 2008 12:07 AM
