TrailBlazer 2002-2009
overheating
Old Nov 27, 2024 | 5:29 PM
oldbeater's Avatar
Default overheating
paastors 2004 trailblazer overheats going around the block. the thermostat has been changed 3 times now has a 180 thermostat, water pump is new, radiator is new, new belt, new ecm, moved sensor from driver side cylinder head to upper radiator hose, i doesn't hold pressure after it heAts up it sprays steam out the fitting the new senser is screwed into. they shaved the heads and it didn't help the parts cannon was fired and missed. i used a thermal gun and it read 180 but the gauge pegs out and the engine loses power..the owner is thinking of scrapping it. i will try to see how much he wants for it.
Old Jan 7, 2025 | 10:34 PM
oldbeater's Avatar
said i could have it for free. he is tired of it. just need to finalioze it. wount count on it until it is in my hands with a title. i am wondering if it could be the transmission or dragging brakes. takes forever to heat up until i go to drive around the block then i heats up right away. i need time to tinker. won't do that until it is mine.
Old Jan 7, 2025 | 10:37 PM
oldbeater's Avatar
the fan clicks and researched it and it says to reprogram the ecm. i gave him all the research it had. he dismissed it. so maybe i can fix it.
Old Jan 9, 2025 | 11:00 PM
oldbeater's Avatar
also no white smoke. haven't checked for blowby though. it is about 10 to 15 miles away so i can drive with the heater on max and when it starts creeping up towards the top i can pull it over and let it cool. the upper rad hose leaks where he put a metric fitting in for the coolant sensor and the threads don't quite match so it doesn't seal good.
Old Jan 10, 2025 | 9:48 AM
Try flushing the engine block. It might have a lot of debris in there.
Old Dec 29, 2025 | 9:41 PM
oldbeater's Avatar
it is in my name now and home. new tires, new windsheild, new rear ac lines, stll overheats though. could the thermostate be in backwards, is that possible?
Jimmy4speed
Oct 21, 2023 8:27 PM
Dawn Canter
HHR
May 28, 2022 11:51 AM
Gsierra11
Aug 2, 2018 1:50 AM
leviathan907
Mar 12, 2012 7:31 PM
CliffGriffin
Jan 28, 2006 10:58 PM
