TrailBlazer 2002-2009
PCV SYSTEM
Old Jan 13, 2008 | 11:40 AM
attibow's Avatar
Default PCV SYSTEM
I have a 2002 trailblazer LTZ, and i have a question regarding the pcv sys. The first question does it have one? because I can't find one. My engine was blowing oil all over the enging compartment, draining approximately 3 to 4 quarts of oil before I found it.I was told to check my PCV hose for freezing, which would cause too much pressure, causing oil to blow out. Has anyone heard of this happening?
Old Jan 13, 2008 | 2:23 PM
RonH's Avatar
Default RE: PCV SYSTEM
From the service manual:
Crankcase Ventilation System Description
A closed crankcase ventilation system is used in order to provide a more complete scavenging of crankcase vapors. Fresh air from the throttle body is supplied to the crankcase, mixed with blow-by gases, and then passed through a crankcase ventilation pipe/passage into the intake manifold.
Results of Incorrect Operation
A plugged PCV Pipe/passage way may cause:
[*]Rough idle[*]Stalling or slow idle speed[*]Oil leaks[*]Sludge in engine [/ul]
bittles
Traverse
Aug 11, 2015 1:03 PM
vf171
Jul 3, 2007 10:29 PM
karaoke04
Feb 16, 2007 12:53 AM
jayno20
Sep 10, 2006 12:21 AM
