TrailBlazer 2002-2009
transmission questions
Old Jan 6, 2008 | 8:28 PM
2004LTGUYANDGIRL's Avatar
Default transmission questions
i have a 2004 LT 4X4 4.2 L6 engine 65,000 miles
what is the model of the transmission?
can i put a transmission pan cooler and bigger oil cooler? no problems just want to upgrade since im moving to the "hills" and will be doing alot of up and down driving?
also what do you recommend as far as aftermarket filters for the transmission?
Old Jan 12, 2008 | 11:47 PM
Sailorsam06's Avatar
Default RE: transmission questions
I doubt that you will have to any of that unless you are towing. I have the exact same make and model as you. The truck comes with a huge engine, and an oversized oil pan for towing, 7 qts. of oil, may i add. It also is meant to tow a 3 ton capacity. Correct me if i am wrong, i am sure this is all taken into consideration for 'hill' driving.
Old Jan 13, 2008 | 9:36 PM
thats what i was told by some of the tranny shops...i didnt know the pan was 7 qt! thanks for the info
Doug Mercer
Mar 6, 2011 1:07 PM
SolomonMan
Dec 29, 2010 1:54 PM
bsoxbito
Dec 29, 2010 12:04 PM
TomS209
Jul 10, 2010 6:33 PM
HNeto
Camaro
Jul 14, 2009 4:59 PM
