TrailBlazer 2002-2009
preventative maintenace
Old Sep 11, 2008 | 8:09 PM
MrSmith's Avatar
Default preventative maintenace
hello. I want to ask about the annual maintenance for my Trl blazer. it has about 55,000 miles on the 2006 model Ls. does it have a timing belt and what does the annual maintenance consist of.
Old Sep 12, 2008 | 6:47 AM
jackyshaikh's Avatar
Default RE: preventative maintenace
Check your owners manual what need to be done.This vehicle doesn't have timing belt.
Old Sep 12, 2008 | 3:32 PM
rbarrios's Avatar
your manual has a guide on maintenance. But I do recommend a transmission fluid/filter change.
other than that- you may want to change the power steering fluid (i did my using a turkey baster- the easy way)... drove for a week and then changed the fluid again.
when I hit 100,000 is when I did more maintenance items
Old Sep 14, 2008 | 1:18 PM
2004LTGUYANDGIRL's Avatar
I WOULD CHECK THE COLOR OF THE TRANS FLUID. IT IS THE RED DIPSTICK UNDER YOUR HOOD. YOU HAVE TO HAVE THE ENGINE RUNNING TO GET THE RIGHT LEVEL. IF ITS RED OR PINK YOUR OK, IF IT LOOKS LIKE OIL, GET HELP
scumpoozie
Nov 1, 2018 12:18 AM
winterkitten
Feb 19, 2015 3:53 PM
Mugetsu388
Mar 4, 2013 6:49 PM
