Replaced transmission but it won't engage
hi Gary I just replaced a 4l60e transmission in my daughter's 2002 Tahoe and yeah I'm having that problem fluid is reading way high and not engaging into any gear at all what do you think it could be
Anyone figure it out? I put rebuilt tranny in put 5 quarts in and it’s readying 3-4 inches above correct level and no shifting. When I put it into any gear the idle changes as if it’s in gear but nothing still neutral. Plz anyone figure the problem out?
I just replaced the automatic transmission on my 2003 Chevy Trailblazer (4.2 I6) with a rebuilt one I bought from a reputable transmission shop in Denver. I do realize that even a rebuilt tranny has the potential for problems but before I yank out the rebuilt transmission out I need some help troubleshooting - PLEASE.
Problem: The transmission won't fully engage in drive and does not engage at all in any other gear (R, 3, 2, 1).
I will preface this by saying I have checked, double checked and checked again, at least 6 more times, all of my connection including oil cooling lines, electrical/wiring, transmission fluid while in park/idling and everything else I can think of.
Here is the situation...
The transmission and transfer case was removed from the engine block as a single unit. NOTE: It was a cumbersome and heavy SOB so if you are a DIY'er, like myself, I would highly recommend you remove the transfer case first then the transmission. The torque converter was NOT removed.
The removal and replacement of the transmission and transfer case was uneventful. Once everything was put back together, I filled it with 11 quarts of Dex VI (recommended by many on this forum) that I bought ($$$ - practically had to finance) from Chevy dealership. The capacity for the torque converter is 6 quarts and the pan is 5 quarts. I then started the car and let it idle while I checked the transmission fluid level. It was 6" up the dipstick so I assumed two things: #1: Either the torque converter was already full (since I never removed and drained it) and I overfilled the system, OR #2: The fluid didn't have a chance to circulate through the system. To test assumption #2 I shifted through the different "gears" (R, N, D, 3, 2, 1) while idling and in doing so I realized the car would not move in any gear. I left it in each gear for 10 seconds and shifted through all gears at least 5 times - to no avail.
The next morning, I jacked the car back up to check, yet again, my connections. I also tried starting the car, checking the (overfilled) fluid, and then tried putting the car in the different gears - while it was up on the jack stands. I noticed when the car was in "Drive" and I pressed on the gas pedal the rear tires would turn but only if I really accelerated. There was clearly no power to the rear end but it did have some (very little) power. None of the other gears would cause the rear tires to turn.
I went and removed approximately 5 - 6 quarts of transmission fluid from the pan. I then re-started the car, checked the dipstick and noticed the level was still high (3" up the stick) and then shifted the transmission through the different gears to see if the tires would turn. No change - When in Drive, the rear tires would turn slowly when accelerating. Otherwise - nada, nothing.
I am at a complete loss and cannot figure out what I am overlooking. It seems that fluid is not circulating but I don't know why. What steps do you recommend I take in troubleshooting this mystery?
Some of my thoughts are:
- Reset transmission?
- Vacuum leak?
- Bad electrical connection?
- Too much fluid?
- Wrong fluid type?
- Bad transmission?
- Take it to the shop to check codes?
- Donate the car to charity?
Thank you, in advance, for your help.
- Vacuum leak?
- Too much fluid?
- Wrong fluid type?
- Bad transmission?
have a 13 tahoe transmission went out installed a used 6l80 . From a 13 silverado. Everything seemed to be working good however after you go over 40 then come to a stop it feels like somone is rear ending you. I was wanting to know if this transmission needs to be reprogrammed ,flashed or relearned . I cannot figure it out. It also after going over 40 when I stopped and tried to go it revved up and then slammed into gear . Any help is appreciated it's driving me crazy
