TrailBlazer 2002-2009
starting problems with 2002 trailblazer
Old Oct 14, 2023 | 8:55 AM
Oliver1's Avatar
Default starting problems with 2002 trailblazer
First let me say that starting problems is the best way to explain it. What happens is that the Trailblazer will start fine but once I drive it some place stop then go to start it the Trailblazer won't start unless I give some gas. Then the engine idles high,so I'll turn it off then try again. What happens then that it will start, it will idle up some, not as high a idle like before .It used to do this every now and again, but now it's happen more often. Has anyone ever had this happen? Can anyone help me with this
Old Oct 15, 2023 | 8:59 AM
chem_man's Avatar
15 Year Member
Is the Check Engine Light on the instrument cluster illuminated?
Have you scanned the OBD II system for Diagnostic Trouble Codes? If not that is the first thing that must be done. If you have had the OBD II system scanned, what are the codes - all of them?
Have you checked the fuel pressure? Have you checked the fuel pressure regulator to make sure it is not leaking?
chevy5932
Feb 14, 2018 12:00 PM
Jakob Proffer
Jan 27, 2018 5:25 AM
KaryHeckman
Aug 2, 2017 11:30 AM
JHasse
Aug 7, 2012 12:32 PM
dianneburke
Jan 23, 2007 12:20 AM
