is there a manual shift override for a 2005 trailblazer?
does anyone know if or where there is a manual shift override for a 2005 trailblazer. i cna't get it to start already had battery and alternator tested . just ordered and new ignition switch from the info i gathered online but i need to get it into neutral to get it towed have no access from behind the vehicle.. any advice is greatly appreciated... thanks
Yes,
look in the manual- tells you how.
You can lift up the boot cover and you should see an orange tab or sorts- lifting on this will allow you to shift out of park...
in fact the manual says something like- when unable to shift and need to get towed- do the following..
Mud_Truckin
June 4th, 2009 1:53 PM
livinloud
January 10th, 2007 5:13 PM
