Chevrolet Malibu
Brake-Transaxle Shift Interlock Manual Override
Old Oct 18, 2010 | 5:48 PM
B C E's Avatar
Default Brake-Transaxle Shift Interlock Manual Override
My 1997 Malibu is having difficulty shifting out of park. I suspect that the wiring between my brake and the solenoid is damaged, but until I find the time to get it fixed, I am trying to locate the manual override so I can at least drive it when necessary.
Does anyone know where it is on this model?
Also, a word of warning for others with the same problem-
I attempted to solve the problem by taping the shifter switch in. The following day I had a drained battery. I suspect the solenoid uses an electro-magnet and I had it running constantly for over 24 hours. I may be wrong about the cause, but it's worth noting the possibility.
Thanks!
Old Oct 23, 2010 | 7:07 AM
nomad76's Avatar
should be a small removable panle right near the shifter i think in the change tray or drink holder. if i remember right its a small red switch you push down.
99fxst99
Sep 15, 2019 10:32 AM
andrewmccluskey
Jan 15, 2014 2:08 PM
shepp04
Sep 29, 2008 5:08 PM
herrgab
Sep 2, 2007 1:01 AM
skides1
Apr 1, 2007 1:32 AM
