Shift Lever Interlock
Old Aug 18, 2013 | 4:46 PM
99fxst99's Avatar
15 Year Member
Default Shift Lever Interlock
Okay, on my `99 Suburban. It has started to refuse to come out of park when the brake pedal is depressed. Sometimes it takes only a slight manipulation of the brake pedal for it to release, sometimes it can be a minute or so of playing with the lever and pedal. I notice sometimes if I depress the brake pedal fully, then release it slightly it seems to help. What can I look for that could cause this? Can the interlock be disabled? this happened yesterday on the boat ramp. It was embarrassing to say the least!
Old Aug 18, 2013 | 7:30 PM
I suspect that the interlock is released by a switch similar to the brake lite switch and probably located next to it. If it's using a separate set of contacts on the brake lite switch, you'll need to check those also.
Old Aug 26, 2013 | 9:56 PM
99fxst99's Avatar
15 Year Member
Never mind, I found there is a way to bypass the interlock if it sticks in park. Piece of cake.
Old Sep 15, 2019 | 10:32 AM
CoreyCasola's Avatar
Default Shifter locked
What did you do to override/bypass the interlock?
KH47
May 8, 2018 12:59 AM
Rakim Rozay Haynes
Dec 31, 2016 12:16 AM
moody1
May 15, 2015 1:33 AM
99fxst99
Feb 17, 2012 10:53 PM
slalom2492
Nov 30, 2010 5:12 PM
