TrailBlazer 2002-2009
Old Aug 11, 2015, 1:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: General Overview
Print Wikipost
VIN to find differential ratio
Old Dec 27, 2011 | 11:41 AM
wolffullmoon's Avatar
Default VIN to find differential ratio
Can I user the VIN to find the differential ratio? We want to buy a travel trailer and the towing capacity is dependent on which rear end we have. As it is a used vehicle with no history, how can I find out?
Jim
Old Dec 27, 2011 | 11:46 AM
Welcome to the forum..
I don't know if the VIN will provide it as easily as the RPO codes will...
you can find the RPO's in the glove box...
What year model are you looking for/at?
Old Dec 27, 2011 | 11:57 AM
A by no means complete list, but a ball park in which to play
G80 : AXLE POSITRACTION, LIMITED SLIP
G81 : POSITRACTION REAR AXLE
G82 : AXLE REAR, 4.56 RATIO
G84 : AXLE REAR, 4.10 RATIO
G86 : AXLE, REAR, LIMITED-SLIP
G87 : RING GEAR, 8.50 INCH
G89 : RING GEAR, 7.50 INCH
G91 : SPECIAL HIGHWAY REAR AXLE RATIO 3.08
G92 : AXLE REAR RATIO, PERFORMANCE
G94 : AXLE REAR, 3.31 RATIO
G95 : AXLE REAR RATIO, ECONOMY
G96 : AXLE REAR, 3.55 RATIO
G97 : AXLE REAR, 2.73 RATIO
GH0 : AXLE REAR, 3.54 RATIO
GH2 : AXLE REAR, 2.29 RATIO
GH3 : AXLE REAR, 2.77 RATIO
GH4 : AXLE REAR, 2.92 RATIO
GK9 : AXLE REAR, 4.63 RATIO
GL3 : AXLE REAR, 6.17 RATIOG
GM1 : AXLE REAR, 2.59 RATIO
GM3 : AXLE REAR, 3.45 RATIO
GM8 : AXLE REAR, 2.56 RATIO
GMC : PLANT CODE PONTIAC, MI, USA
GN9 : AXLE REAR, 4.11 RATIO
GQ1 : AXLE, STD RATIO
GS1 : AXLE REAR, 2.73 RATIO
GS3 : AXLE REAR, 3.73 RATIO
GS4 : AXLE REAR, 3.70 RATIO
GS5 : AXLE REAR, 4.11 RATIO
GS6 : AXLE REAR, 4.56 RATIO
GT1 : AXLE REAR, 2.56 RATIO
GT2 : AXLE REAR, 2.29 RATIO
GT4 : AXLE REAR, 3.73 RATIO (DUP WITH 5 X 1)
GT5 : AXLE REAR, 4.10 RATIO (DUP WITH GT8)
GT7 : AXLE REAR, 3.33 RATIO
GT8 : AXLE REAR, 4.10 RATIO (DUP WITH GT5)
GTY : AXLE, WIDE TRACK
GU1 : AXLE REAR, 2.41 RATIO
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
GV1 : AXLE REAR, 2.73 RATIO
GV2 : AXLE REAR, 5.83 RATIO
GV3 : AXLE REAR, 3.08 RATIO
GV4 : AXLE REAR, 3.36 RATIO
GV5 : AXLE REAR, 3.55 RATIO
GV7 : AXLE REAR, 4.11 RATIO
GV8 : AXLE REAR, 2.72 RATIO
GW2 : AXLE REAR, 2.56 RATIO
GW3 : AXLE REAR, 2.56 RATIO
GW4 : AXLE REAR, 3.31 RATIO
GW5 : AXLE REAR, 2.73 RATIO
GW5 : AXLE RATIO, 3.16 RATIO
GW6 : AXLE REAR, 3.27 RATIO
GW8 : AXLE REAR, 4.10 RATIO
GW9 : AXLE REAR, 2.93 RATIO (DUP WITH GU3)
GWL : SPRING, RR, 9000 LBS CAPACITY
GX1 : AXLE REAR, 3.70 RATIO
GX2 : AXLE REAR, 3.07 RATIO
GX3 : RATIO,TRANSAXLE FINAL DRIVE 3.33
GY2 : AXLE REAR, 3.31 RATIO
GYS : RATIO TRANSAXLE FINAL DRIVE 3.65
GZW : GVWR: 6459 LBS. / 2930 KGS
H01 : AXLE REAR, 3.07 RATIO
H04 : AXLE REAR, 4.11 RATIO, SINGLE SPEED
H05 : AXLE REAR, 3.73 RATIO
H12 : AXLE REAR, 21000 LBS, EATON 21065S, SINGLE SPEED
HA3 : AXLE REAR, 5.29 RATIO, SINGLE SPEED
HC4 : AXLE REAR, 4.56 RATIO
HC7 : AXLE REAR, 5.13 RATIO, 7500 LBS, SINGLE SPEED
HC8 : AXLE REAR, 3.21 RATIO, SINGLE SPEED, TRUCK
HE3 : AXLE REAR, 3.07 RATIO, 3500 LBS, SINGLE SPEED,
HF7 : AXLE REAR, 4.56 RATIO, 10000 LBS, DANA 70, SINGLE
HF8 : AXLE REAR, 4.88 RATIO
HK1 : AXLE REAR, 2.87 RATIO
HK9 : AXLE REAR, 5.86 RATIO 10000 LBS, SINGLE SPEED
Old Apr 16, 2014 | 10:17 PM
neofyte's Avatar
Default front and rear axle ratios
in regard to my 99 suburban K1500 w/AT I have a question: is the rear axle ratio the same as the front axle ratio? I don't know why it would not be, but just checkin'....
Thanks.
Old Jun 24, 2014 | 6:44 PM
jimstrailblazer's Avatar
front and rears should be the same or it will tear something apart.
Old Jun 12, 2015 | 7:52 PM
bigredone's Avatar
rpo list for 1995 2500 4x4? want to know gear ratio and which transmission I have.
Old Apr 10, 2017 | 12:34 PM
SandyJJD's Avatar
rear axle ratio for a 2007 Chevy Suburban K1500
Old Apr 10, 2017 | 12:37 PM
SandyJJD's Avatar
would you know axle ratio for 2007 Chevy Suburban K1500?
Old May 18, 2019 | 1:04 AM
Kenneth Counahan's Avatar
Default Gear ratio
I have a 2000 Chevy Blazer 4.3L 4×4 and I need to find out my rear end gear ratio so I can replace the rear axle bearings. I do not have a RPO code in my glove box that I can find. How else can I find out what it is?
Old May 18, 2019 | 3:16 PM
flyboy2610's Avatar
This site will decode the VIN:
https://chevroletforum.com/forum/vindecoder.php
I don't know if the axle code is something that will be included or not, though.
