What spark plugs
I have a 2002 Trailblazer and it is time to change the sparks. What kind should I use? Is there an alternative to AC Delco - for example NGK, Champion or Bosch - Problem finding AC Delco where I live. Thanks
you will have to get a plug called Iridium it is made by Delphi or AC Delco a regular plug will not work correctly I believe it is the shape of these plugs that fits correctly into the coil also these Iridium are guaranteed to last in excess of 100,000 miles and cost $9 each
Vlado welcome to the forum...
I too would recommend the stock spark plug, any other brand is likely to not last as long as the original and any claims of more power or better MPG is pure hype..if a plug alone would improve power and MPG the auto manufactures would already be all over it...
Maintenance Items
Application Part Number
Automatic Transmission Filter Kit GM P/N 24200796
Air Cleaner 4.2L L6 MFI (LL8) AC Delco® Part No. A2014C
Engine Oil Filter 4.2L L6 MFI (LL8) AC Delco® Part No. PF58
Spark Plugs 4.2L L6 MFI (LL8) AC Delco® Part No.41-965
Fuel Filter 4.2L L6 MFI (LL8) AC Delco® Part No. GF831
Windshield Wiper Blades 20.0 inches (50.8 cm)
Back glass Wiper Blade 14.0 inches (35.6 cm)
Maintenance Items
epekarik
Jul 14, 2006 12:51 AM
