TrailBlazer 2002-2009
Where to source a replacement LR to RR brake line for 2002 trailblazer?
Old May 12, 2017 | 1:07 PM
Racerx1662's Avatar
Default Where to source a replacement LR to RR brake line for 2002 trailblazer?
Replacing rear sway bark links & accidentally nicked rear brake line with mini-grinder...ughhh! Probably only brake line remaining that wasn't very corroded & ready to star leaking. Thus need to replace LR to RR brake line (routes across vehicle & over fuel tank). Seems fitting is metric, 1/2-1.25 thead?
Thanks for any help with this.
Old May 13, 2017 | 12:35 PM
Try the links below. You can also make your own with steel tubing and a double flare tool.
https://www.carid.com/beck-arnley/be...163626332.html
Best Brake Line Parts for Cars, Trucks & SUVs
https://www.summitracing.com/search/...erms-_-keyword
