Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
2009 Traverse 3.6 p0016, p0017, p0018 p0008
Old Aug 11, 2019 | 9:04 PM
ruggeri5054's Avatar
Default 2009 Traverse 3.6 p0016, p0017, p0018 p0008
So I picked up an 09 Traverse from a friend, 1200 dollars. Had timing correlation codes on intake/exhaust bank1. I removed the cover, installed a new full timing set. Re assembled and codes came back. Made a light rattle.
Removed covers again, inspected. Chain is tight but when I rotate the engine, the rear cam VVT sprocket (Exhaust) (bank 1) has movement. As I rotate the crank, the sprocket will shoot forward until the next revolution. Every time I rotate, it does this.
When it ran, it showed misfires on 1,3 and 5. It ran very smooth (could not feel misfires) when I gave it gas, only idled rough and performance was lacking as it should be if it is not completely in time. I checked valve springs and rollers (no gaps between lobes), does not appear to have bent valves. I will do a compression and leak down test to confirm.
NOW here is where I left a part out, I did NOT use the cam alignment tools. I held the cams in place with wrenches. I learned from this and ordered a set. When I inspected it the second time, the cams were off from each other by about 5 degrees or so.
So my problem is that I can turn the cam shaft with a wrench on the exhaust cam with full movement of the phaser WITHOUT moving/turning the sprocket. Should I buy a set of phasers or is this only because there is no oil inside of it during my inspection.
Thank you!!
