Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
2012 Traverse 8-way power drivers seat.
Old Oct 22, 2023 | 5:03 PM
U101's Avatar
Default 2012 Traverse 8-way power drivers seat.
Hi,
Is someone able to confirm if the front end (under the knees) of the driver's seat should move up? The horizontal switch that move the seat back and forth also has the ability to lift the rear of the seat but the front does not move. I also have a separate vertical switch in front of the horizontal one and nothing happens (not even the slightest sound) when I push it up but when I push it down it makes one quick sound, like something hit its end, and then nothing.
Thank you
Old Oct 22, 2023 | 8:35 PM
it should go up, to a limit. Does it go down?
Old Oct 23, 2023 | 11:29 PM
U101's Avatar
No, it doesn't move in either direction, but when I push down on the switch it does make a sound as if it hit its limit and it is a low as it can go. , as opposed to no sound made when I push up.
Old Oct 24, 2023 | 2:10 AM
unbolt the seat lay it down, and look and see what stopping the mechanism. Something is either worn out , seized, bent or something.
Old Oct 24, 2023 | 7:43 AM
U101's Avatar
Will do, I'll see if I can take a look this coming weekend and see what I find. Thanks
Old Nov 10, 2023 | 10:45 AM
U101's Avatar
So I finally had a chance to remove the seat and check underneath and it doesn't look like the front part of the seat goes up/ down. In image 1 I circled the back part of my seat and I saw it move and the mechanism moves as it should. In image 2 I circled the mechanism in the front part of the seat and it is different and does not appear to be built to move. Image 3 shows 2 of the 3 motors under my seat, there is another one to the left that is not in the image, but could not say what they move.
Old Nov 10, 2023 | 2:24 PM
most likely one motor for forward/back, another for rear up/down, and another for front up/down.
Cj.Clifton
2007 - 2013 (GMT900)
Aug 24, 2021 1:56 PM
Cheba
Mar 14, 2019 12:00 PM
Jon Landau
Aug 17, 2015 6:08 PM
Poppop47
Feb 11, 2014 6:12 PM
hub_cap
Apr 8, 2013 6:49 PM
