Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
2012 Traverse issues
Old Aug 9, 2022 | 10:42 AM
winchester300's Avatar
Default 2012 Traverse issues
#1 Fans not coming on for coolinig, OBD scanner showed 82 F but gauge on dash shows 210 ? no overheating, when sitting idling on 90 degree day, no fans turn on, ? not sure if thermostat in or not, daughter just purchased vehicle.
#2 AC condenser fans not turning on with AC on
#3 how do you recalibrate an actuator mode door when putting new one back in ?
Thanks in advance for any help
I pulled a vacuum on A/C and will recharge to see if high pressure on gauges goes up enough to trip fans on ?
right now seems like low pressure reads high and high pressure reads low on gauges, also compressor cycling on and off and high pressure line hot but no fans etc No A/C working at all
Old Aug 10, 2022 | 3:37 AM
oilcanhenry's Avatar
Try disconnecting the battery, for a time, as a start. The left-side interior actuator motor self-adjusted on my 98 K1500. Works great now, but a b***th to get to.at my age. Let me know if this helps or not.
Av8er
Mar 13, 2017 8:10 PM
in2pro
Sep 13, 2013 3:25 PM
RwChevy967
Jul 12, 2013 3:58 PM
RwChevy967
Jul 11, 2013 10:56 AM
mj58595
Oct 7, 2006 1:03 PM
