Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
2018 traverse dash removal
Old Jul 17, 2020 | 11:45 AM
dbmarek's Avatar
Default 2018 traverse dash removal
I’m trying to find a video to help me remove my dash so I can fix my ac. I can’t find one that is helpful. I need to replace the evaporator, dryer, and expansion valve. I appreciate any help.
Old Jul 19, 2020 | 9:18 PM
Gumby22's Avatar
Shouldn’t a 2018 still be under warranty??
I can’t help you with a video, but basically, the dash needs to come out as a unit. If you remove the trim from the ends of the dash and center console, you’ll see a metal framework - it’s the primary bolts and supports for that framework (instrument panel carrier) that have to be removed to pull the dash out and access the HVAC housing. You’ll have to remove pretty much all the dash trim, steering column, center console, and both front seats to do it.
If you want a specific, step by step procedure, you can buy a service manual (factory or aftermarket such as Chilton or Haynes) or get a temporary subscription to all data, Mitchell/pro demand, identifix, or other service info provider.
Blacktooth
Traverse
Sep 28, 2019 10:53 AM
larful
Traverse
Oct 3, 2018 10:20 PM
rjkdhk@gmail.com
Jun 12, 2018 9:56 AM
SPulliam
Traverse
Mar 30, 2018 8:48 PM
