2021 Traverse Driver Side Blinker
I have a 2021 Traverse and recently the driver side blinker started blinking faster than normal. Then out of nowhere it started working. Now the blinker is blinking fast again. I checked all of the bulbs and none of them are blown. The 4 way flashers also work properly. If anyone has any suggestions of what I should check next, that would be great.
Thanks,
Ryan
Thanks,
Ryan
Are they factory style bulbs, or some aftermarket "upgrades"?
check the bulb socket and wiring. You could have some corroded contacts, chafed wires etc.
Try swapping out the fuse.
If all else fails, invoke your warranty.
Hey Camarodude: I also have a ‘21 Traverse with the same problem (right side). My other ride is a ‘13 Camaro 2SS. Small world!
I would really appreciate any info you could share on this issue. I can’t even locate a fuse for the turn signals! If you could share their location I would greatly appreciate it.
Many thanks,
Stan
Many thanks,
Stan
Chevrolet Forum News
Feb 4, 2021 8:28 AM
