Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
2021 Traverse Driver Side Blinker
Old Mar 29, 2024 | 8:13 PM
Camarodude28's Avatar
Default 2021 Traverse Driver Side Blinker
I have a 2021 Traverse and recently the driver side blinker started blinking faster than normal. Then out of nowhere it started working. Now the blinker is blinking fast again. I checked all of the bulbs and none of them are blown. The 4 way flashers also work properly. If anyone has any suggestions of what I should check next, that would be great.
Thanks,
Ryan
Old Mar 29, 2024 | 8:23 PM
Are they factory style bulbs, or some aftermarket "upgrades"?
check the bulb socket and wiring. You could have some corroded contacts, chafed wires etc.
Try swapping out the fuse.
If all else fails, invoke your warranty.
Old Mar 29, 2024 | 8:52 PM
Yes they are factory bulbs. I checked the socket and there wasn't any corrosion. I swapped the left and right front bulbs and that didn't make a difference.
Old Mar 30, 2024 | 1:31 AM
CowboyRodeo's Avatar
yup, invoke your warranty, one of the best thing about having a newer car.
Old Nov 30, 2025 | 4:45 PM
StanT's Avatar
Hey Camarodude: I also have a ‘21 Traverse with the same problem (right side). My other ride is a ‘13 Camaro 2SS. Small world!
I would really appreciate any info you could share on this issue. I can’t even locate a fuse for the turn signals! If you could share their location I would greatly appreciate it.
Many thanks,
Stan
Old Nov 30, 2025 | 11:58 PM
Turns out my tail light had water in it and it caused some of the LEDs to be bad. I had to replace the whole tail light assembly.
owensone
Traverse
Jun 3, 2023 6:07 PM
0Gadget0
Traverse
Dec 19, 2022 6:29 PM
Craig1050
Traverse
Apr 30, 2022 8:57 AM
Jmartz80
Traverse
Jun 2, 2021 5:32 PM
Chevrolet Forum News
Feb 4, 2021 8:28 AM
