Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
Passenger window operation from driver door panel
Old Nov 22, 2019 | 6:11 PM
Malkie's Avatar
Default Passenger window operation from driver door panel
The passenger window will not operate from the driver side switch. It does work from the passenger side switch.
Old Nov 22, 2019 | 10:19 PM
inspect the switch
If the switch is ok then check the wires in the door harness, which get bent back and forth a lot.
Old Dec 9, 2019 | 6:07 PM
c5mech's Avatar
The switch module comes out pretty easily. Discount the wire connectors, open the module. Not to easy but it can be done. Clean the "rocking" metal contacts. I used a pencil eraser. Reassemble, install in vehicle. It Should work now. I've done this several times and it works well for me.
Hope it works out for you.
Desp
Oct 3, 2016 7:06 AM
pkupman_77
Aug 22, 2015 2:50 PM
Soxman
Sep 8, 2014 12:21 AM
Ryang25
Aug 4, 2014 9:26 AM
