Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
service stabilitrak / reduced engine / traction control off/ parking assist off
Old Jan 21, 2016 | 2:07 PM
  #11
grand bayou's Avatar
Smile
so you are saying that the customer is too dumb read a code that says engine misfire. and by putting the code where the average code reader wont work you must go back to the dealership that over charges for everything..
Old Jan 21, 2016 | 10:34 PM
  #12
cleveland63b's Avatar
"average code reader" is what? I've never seen a code reader that won't pull p codes and any shop that does diag can pull the codes they need, hell any person that buys a real scanner can do it. The general public can't even pop their own hood and fill washer fluid so yes I don't believe or trust most customers to be able to diagnose anything on their own, same reason tpms systems had to become a regulation because drivers are too lazy or incompetent to make sure their tires arent flat.
Not to mention there are literally thousands of things that can cause a malfunction indicator to come on not just a misfire.
your comment about overcharge is tough to debate because it varies case by case and by location but if you had any idea what kind of expense it is to run a shop/dealer or even try to make a living as a tech you wouldn't be so quick to speak.
Old May 26, 2016 | 1:57 PM
  #13
Jamie Davis Maddox's Avatar
Call nhtsa at 8883274236 and report so a recall will be initiated. The more complaints they receive, the more likely they will investigate. I'm have same problems. Went to dealership for the third time today and I am sick of it!
islandarmor
Avalanche
323
Sep 18, 2025 1:09 PM
dcanada92
Jan 12, 2016 8:46 PM
Dray
Apr 17, 2014 9:43 PM
