Uplander 2005-2009
Platform: U-Body
06 uplander issues
Old Aug 31, 2011 | 8:22 PM
06uplander_lt's Avatar
Default 06 uplander issues
So I found out how to fix my flickering lights and will be getting the kit to fix that soon. I also have a issue with rough idle and it seems like its getting worst... Will this also fix my problem when I do the GM PART # 25854910 CATEGORY: Voltage Regulator.
Thanks,
Jerry
Old Sep 1, 2011 | 12:43 AM
Anyone? Thanks!!
Old Sep 1, 2011 | 9:28 PM
free bump
Old Sep 1, 2011 | 10:14 PM
EinST's Avatar
Welcome to the forum. I doubt it, based on my reading of the TSB #05-06-03-003C that shawnvw kindly posted in thread https://chevroletforum.com/forum/upl...remlins-18494/. But, who knows?
Old Sep 3, 2011 | 5:34 PM
Papa Bear's Avatar
Originally Posted by 06uplander_lt
I also have a issue with rough idle and it seems like its getting wors(e)
Jerry
Talked to a forum friend who is in GM management, he says there is no TSB on rough idle and the likely suspect is a dirty throttle body. Clean any crud from the inside of the throttle body around the butterfly blade gently with a rag dampened with cleaner and see if that helps.
Old Sep 4, 2011 | 12:04 AM
Thanks for your kind help!
Jerry
PatrickCairns
Uplander
May 31, 2011 9:00 AM
jsehoule
Uplander
Feb 4, 2011 11:36 AM
pplimf
Uplander
Oct 30, 2010 12:20 AM
Buck3rd1962
Uplander
Oct 27, 2008 8:43 PM
RoadWarrior
Uplander
Nov 10, 2007 10:25 PM
