Uplander 2005-2009
Platform: U-Body
07 uplander hesitation from start.
Old Apr 16, 2017 | 5:42 PM
Hank Strong's Avatar
Default 07 uplander hesitation from start.
The trans. seems (on occasion) to not want to go, then it catches and takes off. Only does this on occasions, and only when taking off. Otherwise it works fine.. Is this an internal trans problem, or what? (Not an engine problem)
Old Apr 21, 2017 | 1:05 PM
Papa Bear's Avatar
It sounds to me like a dirty throttle body
https://www.youtube.com/results?sear...+throttle+body
Old Apr 23, 2017 | 12:32 AM
Perhaps hesitation is the wrong word...The engine speeds up but it momentarily acts like it is in neutral. It seems to be more prevalent before the engine warms up. ATF fluid and filter has been changed.
Old Apr 23, 2017 | 9:05 AM
AlexLok96's Avatar
hey,
I have had a similar problem. Sounds like a bad solenoid in the transmission. Had a problem in my 06 montana sv6 where it would it would act like its in neutral and suddenly bang into gear from a stop. I got a code for the pressure control solenoid but changed all 4 of the solenoids as it is not an easy job to get to where the solenoids are at.
