Uplander 2005-2009
Platform: U-Body
09 uplander 3.9 l trans issue
Old Jul 5, 2023 | 10:27 AM
march2008's Avatar
Default 09 uplander 3.9 l trans issue
It has 88,412 km or 54936 miles.
When I put it in drive it takes too much time to engage. If I put it into low it engages normally. I first noticed the problem when I hit the throttle hard from a stop . It revved up and then banged hard into gear. It seemed to be slipping at times. Shifting it manually it seems to work fine. There are no codes. I put my cheap scanner on it and in the trans section for live data it shows 0 rpm for the Output Shaft Speed Sensor as I'm driving it.
Has anyone else encountered this? I've tried online for info on this with no luck. I don't know where that sensor is and can't seem to find any info without having to spend money.
Any help is greatly appreciated.
John
Old Aug 12, 2023 | 2:44 AM
EHCanadian83's Avatar
How's your transmission fluid level?
msjs91011
May 25, 2021 11:55 PM
Huntfish12
Dec 8, 2015 12:15 AM
Paveman
Feb 23, 2014 5:16 AM
wickedchev
Nov 30, 2012 12:03 AM
ppeck50
Dec 11, 2010 2:18 PM
