Uplander 2005-2009
Platform: U-Body
2005 Uplander LT sqeaky belt
Old Aug 9, 2009 | 1:37 PM
ericmckinney's Avatar
Default 2005 Uplander LT sqeaky belt
I own a 05 uplander LT and my belt started squeaking bad so I looked at the tensioner and the pulley was sticking a little so I replaced that and it has been working fine for a while now, but the problem as come back and I notice when the A/C is turned on and the engine is revved up a bit. When the A/C is off the problem goes away. Any suggestions out there?
Old Aug 10, 2009 | 6:24 AM
Papa Bear's Avatar
Did you replace the belt when you did the tensioner ??
Old Aug 10, 2009 | 12:58 PM
Papa Bear,
I did replace the belt with the tensioner, I am at wits end here. As soon as I turn the A/C on high it starts to sqeal and annoys me. I am located overseas and can not take it to a dealer. It sounds like all the noise is coming from one pulley itself and it seems as it might be the one to the right of the altenator, it looks as if it is a stand alone pulley
Old Aug 10, 2009 | 1:57 PM
Papa Bear's Avatar
Are you sure the A/C compressor isn't squealing ?? You might spray a little water on the belt while someone revs up the engine... if the noise goes away then it may be the belt.
Good luck and keep troubleshooting...keep us informed.
Old Aug 10, 2009 | 5:16 PM
shawnvw's Avatar
Banned
sounds like the a\c compressor seizing up to me
Old Aug 13, 2009 | 1:13 PM
So you guys are saying that the A/C compressor might be seizing up, never though of that, but if it is doing that would the A/C continue to work at full throttle?
landon101
22
Nov 14, 2021 10:48 AM
OtherCarASaab
Aug 31, 2012 12:00 AM
moon i
Dec 16, 2011 9:45 AM
hohren
Uplander
Apr 7, 2010 8:35 PM
hollijb
Feb 12, 2007 12:21 PM
