Uplander 2005-2009
Platform: U-Body
2006 Key Fob Programming
Old Jun 26, 2012 | 7:39 PM
PG2676's Avatar
Default 2006 Key Fob Programming
How do I program a new key fob on my '06 Uplander? I've already tried the "hold the unlock button, cycle the ignition key twice, release the unlock button" trick. Please save me $80 and keep me from having to take it to the dealer to do this for me. The remote already cost $135!
Old Jun 26, 2012 | 10:46 PM
cartek's Avatar
Try ingition on, don't start the engine, then press lock and unlock together on the remote. That is how to re-sync the remote, not sure if it will prgram a new one, but it's worth a try!
Old Jun 27, 2012 | 10:24 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> PG2676,
Sorry, but a scan tool is needed to access the body control module to program the remote properly.
If you need additional assistance in the future, please feel free to contact me privately.
Louis
GM Customer Service
Old Jun 27, 2012 | 1:06 PM
chrisadams's Avatar
Find a less greedy dealer.
I called twenty local (sort of) dealers.
Prices ranged from 40 to 120 for programing all remotes.
They have to program all of them, that is, you need your old ones and new one together.
The vans only handle 4 remotes total.
Prices on remotes ranged from 48 to 140 at the twenty dealerships.
Only a couple would only program if you bought them there. Those had the highest prices by far.
I bought two off Ebay for 48 bucks, shipped, brand new.
Then had them programed for 50 bucks (closest, cheaper in gas than driving to the 40 dollar place).
I have 3 remotes now, only need two but by doing two at once I saved a possible 50 buck charge later.
American dollars, fyi.
Old Jun 28, 2012 | 4:54 PM
PG2676's Avatar
Ya, the shop rate in my neck of the woods is 1/2hr minimum at $120/hr. Plus tax and "shop supplies".
Old Sep 14, 2012 | 9:48 AM
chrisadams's Avatar
Originally Posted by Ronaled02
Hi dear am newbie here and i want to ask a question which is that I am buying the key fob off of ebay. does anyone know how to program these things. or where I could find the programming instructions?
You should really read the thread from the beginning.
The 2006 and up Uplanders can only be programmed by a dealer.
You call your local dealers and find out what they charge.
Prices vary from dealer to dealer.
Also ask if they will do remotes you bring in from somewhere else.
This is a GM 'money maker' idea, to not allow the owners to program the remotes like most other vendors allow.
Or one of the many reasons GM went under.
Old Nov 8, 2013 | 1:05 PM
autoexpert's Avatar
Default Best key FOB
Uplander:
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote.
Please contact your dealer for programming.
Link : Chevrolet Uplander Keyless entry key programming instructions - ProgramKeyFob.com
Old Apr 30, 2017 | 4:16 AM
RafaĊ‚ Chrzan's Avatar
Hi i'm new on this forum and new owner of uplander 06 awd without remote start , did u ever try this.
barecub
Nov 13, 2018 6:13 PM
kcarberry
Jan 24, 2014 5:37 PM
kaja
Sep 21, 2013 4:23 PM
tasetliff
Feb 8, 2012 9:29 PM
kaja
May 22, 2007 9:55 AM
