Uplander 2005-2009
Platform: U-Body
ABS light
Old Apr 23, 2012 | 8:58 AM
calebs02's Avatar
Default ABS light
Hey everyone, Got a quick question for the gurus!!
I have a 2006 uplander, and the ABS light comes on intermittently! Only when the wheels are turned fully to the right! Ive read that the wheel speed sensor harness has been known to break internally. Is this true and how much of a pain is it to replace!!??
Also i got a 0446 code from the check engine light, Replaced the gas cap and of course its not that simple! can anyone tell me the location of the evap valve and any 0ther info associated with this code?
Old Jul 24, 2014 | 4:18 PM
srp204's Avatar
You can buy a new cable and replace it yourself, but once the wires get exposed, the corrosion runs inside the plastic cover and just cutting out or adding a new end is very temporary. I thought I found the damaged piece and cut back 3 inches each way but the wires could not be soldered because of the corrsion. New cable is $20 takes less than an hour.
kaptain howdie
Dec 16, 2014 8:20 PM
Bulldog9539@gmail.com
Sep 4, 2011 1:54 AM
Deteoni
Mar 28, 2009 1:39 PM
onetimeatbndcamp
Oct 10, 2006 1:16 PM
